Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
IPC footprint sizes - less, nominal or more?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: IPC footprint sizes - less, nominal or more? (Read 7665 times)
shadewind
Frequent Contributor
on:
March 27, 2011, 10:47:27 pm »
I'm designing my first SMT board and noticed that A!tium has three versions of all IPC footprints marked L, N and M. I understand that these are different sizes depending on how much you need to pack the components.
How hard is it to solder the high density (L) footprints? I'm thinking mainly for QFP 0.5mm and 0603 components. Since this is the default (default in A!tium for chip caps and what Luminary used in the component library for A!tium which you can get at their website), I had already designed the board when I noticed this. Is it very hard to solder this compared to the nominal or larger sizes or should I simply leave it as it is and give it a try?
Since this is a two-sided board, the decoupling caps and associated routing on top close to the MCU is indeed quite crowded as it is so a change to larger footprints might cause some trouble.
Last Edit: March 27, 2011, 10:54:45 pm by shadewind
Logged
DrGeoff
Country:
Re: IPC footprint sizes - less, nominal or more?
Reply #1 on:
March 28, 2011, 04:31:29 am »
It's not hard to hand solder these components.
I'd recommend using a magnifier to work with the board though. There are several techniques discussed on the forum here for soldering SMT parts and I usually use a syringe of flux paste applied to the pads to be soldered. This helps position the part since the flux paste is sticky, and the solder flows very easily onto the pad and pin without bridges between adjacent pins.
Logged
Was it really supposed to do that?
shadewind
Reply #2 on:
March 28, 2011, 05:04:01 am »
Right, but do you mean that it's easy regardless of pad size? I'm considering going up to nominal at least to be on the safe side even though I might have to modify the routing a bit.
By flux paste, do you mean solder paste or simply just flux? I do have flux but not solder paste as it is quite expensive, at least the ones I've seen.
Logged
DrGeoff
Country:
Reply #3 on:
March 28, 2011, 05:28:10 am »
I always lay out a board with the large size pad for the component. If you get a component whose tolerance is on the higher side then it's harder to solder on a smaller pad. It's also much easier when hand soldering.
Flux paste is just that. Flux in a syringe.
Like this
http://www.mgchemicals.com/products/8341.html
Logged
shadewind
Reply #4 on:
March 28, 2011, 06:48:59 am »
I'll try and use the largest size that I can comfortably fit on the board. I don't want to move my decoupling caps too far away, though.
Edit: The largest footprint was quite a bit larger than the smallest I was using. It's proving to be not very easy to reroute this...
Last Edit: March 28, 2011, 09:32:51 am by shadewind
Logged
ToBeFrank
Regular Contributor
Country:
Reply #5 on:
March 28, 2011, 04:46:22 pm »
I use nominal, although I don't solder by hand. I use a solder paste and a small infrawave oven to reflow. You can get solder paste from a few places online for $30US or so. A little of it goes a long way. I haven't had a failure yet due to soldering.
Logged
ToBeFrank
Regular Contributor
Country:
Reply #6 on:
March 28, 2011, 04:52:12 pm »
One thing I forgot to mention, I think it was in Tom Hausherr's blog I read that he uses least for 0603 and smaller components to help prevent tombstoning. This also applies to reflow though.
Logged
shadewind
Reply #7 on:
March 28, 2011, 04:54:29 pm »
I finally managed to fit the components anyway so I think I'll go with "Most". Quick question, for decoupling caps, it doesn't really matter whether the ground or the power pin is closer to the pin, it's the total impedance that matters, right?
Logged
allanw
Reply #8 on:
March 28, 2011, 06:29:55 pm »
I use nominal and solder them fine with an iron.
When doing them by hand, I think it helps to have the pad extend past the actual pin, otherwise it's very difficult to get your iron to touch both the pad and pin to solder with. With tall 1206 capacitors sometimes this is hard. If you're reflowing then this is less of a problem.
Logged
shadewind
Reply #9 on:
March 28, 2011, 06:48:27 pm »
I'll go with "Most" since I already converted the board to that and I don't want to have to redo it
When I get the board, I can get a feel for how difficult it is myself so I'll know for next time.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
