Author Topic: IP rated encoder for HMI  (Read 408 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 04, 2023, 08:21:47 am »
We have a potentiometer on our HMI, and the is only one reason why, we could not find an IP rated encoder. But surely this cannot be the case? surely using HMI's in the great outdoors is a thing?
Offline ArdWar
  • Country: sc
Re: IP rated encoder for HMI
« Reply #1 on: July 04, 2023, 09:05:50 am »
Huh? Short search on mouser returns sizable selections. What IP rating do you need?
For extreme harsh environment I usually go directly to magnetic shaft and hall effect sensor. Custom made but there aren't that many option when you want zero enclosure penetration.
