Hi Guys
Well inspired by Dave’s last video I decided to do the Australian phone ring duration the hard way
The duration is: 400ms ring, 200ms delay, 400ms ring, 2000ms delay, repeat.
hehe...
Both chips reset each other, so if the decade counters started batty it would fix itself.
Sometimes decade counters can start with more than one bit set, and all bits continue through the counter until reset.
This schema doesn’t include the rest of the circuit to drive the ringer solenoid, just the ring durations.
If you see any simplification please let me know
Cheers, Brek.
