I built an exposure box using twelve 3W 395-405nm UV LEDs, driven by three small constant current LED driver modules. I was first thinking of implementing the box using those small UV LEDs, but as a lazy person I ended up using twelve high-power UV LEDs as I hated the idea of wiring all those small LEDs and resistors. The exposure time is 1.5 minutes, which is quite nice. Maybe the LEDs wavelength is not quite optimized for the PCB or the glass I am using to keep the film and the PCB together, but it gets the job done. At the moment the box is used as single sided, but it can be upgraded to double sided very easily, if needed. The distance between the LEDs and the PCB was determined experimentally so that the light was even across the PCB. With my LEDs the distance is about 7cm.
