Author Topic: Precision Load Cell (Wheatstone Bridge) Simulator  (Read 13308 times)
Offline Overspeed
Re: Precision Load Cell (Wheatstone Bridge) Simulator
« Reply #50 on: August 05, 2024, 02:16:27 pm »
Hello
Thanks for explanation I agree but
a strain gage is a not a rubber band , a strain gage have a gage factor so resistance variation is limited and limited also by the fixation / gluing so a simulator will match the reality no need of a wide resistance variation but better to have an very accurate link between Delta resistance and output voltage of the bridge
AC bridge request ( or have in the past as HBM AC bridge ) complex electronic with some advantages but I use DC since years that work easy
I link a interesting doc on 1/4 bridge and a symmetrical dual op amp circuit
I agree on the output voltage to voltage ref ratio solution
Regards
OS
Offline hozone
« Reply #51 on: August 06, 2024, 07:54:27 am »
Thanks again.
The DAC, or any other active component would work better for this design.
I think I'll go for a +-0.003% VExc absolute error label for this passive simulator. Even if it's a unknown behavior to me  :palm:
Offline Overspeed
« Reply #52 on: August 08, 2024, 06:07:53 am »
Thanks again.
Hello
Can you provide the calculation : I'll go for a +-0.003% VExc absolute error label
That interesting
Regards
OS
Offline hozone
« Reply #53 on: August 08, 2024, 09:43:26 am »
Hi @Overspeed,
Don't know if I'm right, and why it's like so, but:
Excitation 10.024V readings (expected, read and abserr in mV)
 range   expected      read    abserr
   0.0      0.000     0.181     0.181
   0.5      5.012     5.311     0.299
   1.0     10.024    10.316     0.292
   1.5     15.036    15.314     0.278
   2.0     20.048    20.320     0.272
Excitation 4.999V readings (expected, read and abserr in mV)
   0.0       0.000      0.087     0.087
   0.5       2.500      2.647     0.148
   1.0       4.999      5.146     0.147
   1.5       7.499      7.643     0.145
   2.0       9.998     10.142     0.144
Locking at the results above (for all ranges expect 0.0):
  • absolute error is almost 0.146(mV) when Vexc is 5V (5000mV), so 0.00292%, let's say 0.003% * VExc => 0.15mV
  • absolute error is almost 0.285(mV) when Vexc is 10V (10000mV), so 0.00285%, let's say 0.003% * VExc => 0.3mV
Note that absolute error for 0.0 range is almost 1/2 (0.003% * VExc)
Offline hozone
« Reply #54 on: August 20, 2024, 03:47:59 pm »
Little updated.
I've notice the 0.272mV shift even on simulator on the R1/R7/R5/R8 branch, given a Vexc of 10V. (see image).
Is it somehow correlated?  :-//
