... Did you test PPTCs only or also in combination with reverse-polarity shorting diodes ?
I'm still afraid that in an extreme case the diode blows before the PPTC trips. This would render my protection circuit useless.
If choosing this method, you DO have to be CERTAIN that you can achieve 2X Poly rating !! Higher even better !! With a popular 1.5KE
device, no problem at all. !!
BUT, if the fault energy collapses to say 1.5-1.2X continuous, then the protection device will sit there and COOK !! and protect the Poly !!
So yes, you need to do the sums. On occasions, when I really have to use this method (motors etc), I put a Thermistor on the
Protection device, usually have one on the pass transistors, heatsinks etc anyway - as a master failsafe.
The 2nd method is a zener (or sensor) triggered FET etc to "blow the fuse", but that can also suffer from the same 2X 3X issues.
PLUS it had the added problem of false or inhibited firing due to RF / switching noise from the load (ie Inductors, motors etc).
The FET gate is a high gain amp after all.
The 3rd method is "fast blow" or HRC type fuses, which can literally beat a semi (we use them in EVs), but they're expensive and
can literally blow if they
think there's a short coming :-).
The 4th method I've used is a Saturated PNP Pass transistor (NO polyfuse), with the OV detect at the base, turning it into a current limiter
or latched off !! BUT you STILL have to worry about load being connected in reverse .. yadda yadda
So after years of trying ALL sorts of methods, I've settled with matching a poly with a transorb, and optional thermal sense.
If you're not going to sell 100s of these, or put them in critical locations, then just go with a fuse and Zener.
