Author Topic: What is the role of Q3 in this LS TTL schematic?  (Read 572 times)
Offline VinzCTopic starter
  • See you later, oscillator.
« on: August 12, 2024, 11:17:07 am »
Hi again.
Out of curiosity I wanted to check again the internals of Low Power Schottky TTL circuits and I stumbled upon this schematic:
I think I overlooked that but now I wonder: what is Q3 doing here? There is a resistor in standard TTL instead of this transistor, so what is its role, exactly?
Thanks in advance for any hint/info.
Offline BILLPOD
Re: What is the role of Q3 in this LS TTL schematic?
« Reply #1 on: August 12, 2024, 01:23:39 pm »
Good Morning Vinz, I am curious what xistor Q1 is, that has 2 emitters :scared:
Offline edavid
« Reply #2 on: August 12, 2024, 02:43:10 pm »
Q3 is an active pulldown that turns Q6 off more quickly than a resistor pulldown.
« Last Edit: August 12, 2024, 05:24:58 pm by edavid »
The following users thanked this post: VinzC, Roehrenonkel
Offline moffy
« Reply #3 on: August 12, 2024, 02:58:09 pm »
Bipolar transistors can have multiple emitters, it's often used for current mirrors if say one wants twice the current out for that coming in, a matched transistor with two emitters will often be used. You could think of the analogy as two transistors with C-C and B-B but the emitters are separate.
« Last Edit: August 12, 2024, 03:01:10 pm by moffy »
Online Zero999
  • 0999
« Reply #4 on: August 12, 2024, 06:52:20 pm »
It's equivalent to many transistors with their base and collector terminals joined. In some cases the transistors will be different sizes i.e.take up different amounts of room on the chip.
Offline bson
« Reply #5 on: August 12, 2024, 09:11:48 pm »
Note also the Schottky transistors (with an S shape diode symbol).
Offline TimFox
« Reply #6 on: August 12, 2024, 09:16:50 pm »
The multiple-emitter input transistors are why this type of circuit is called "TTL" (transistor-transistor logic), as opposed to "DTL" (diode-transistor logic).
Many BJT logic ICs are called TTL, when they are actually DTL with Schottky diodes.
A generic name for this style of IC is "current-sinking logic", where the current to be sunk is either diode current or emitter current, and the sink is a grounded-emitter NPN output (usually with active pull-up circuit).
The important feature of current-sinking logic is that the input-low input current is much higher than the input-high input current, as opposed to CMOS which is more balanced.
The following users thanked this post: AndersJ
« Reply #7 on: August 13, 2024, 09:13:20 am »
Sorry for being late, indeed that's a classic configuration encountered in transistor gate logic, as explained earlier.
That is interesting  :-+
I don't remember ever seeing such a configuration. I only needed that answer to finally open the gates to literature on this topic (e.g. https://electronics.stackexchange.com/questions/676573), so thanks a bunch for the tip!
EDIT: If I were to give that setup a name I'd go for "active turn-off" as the symmetric version for a PNP transistor would be an active pullup instead (I guess).
« Last Edit: August 13, 2024, 10:39:44 am by VinzC »
