Hello,
straight to the questions:
1. Can I connect 3 TLC5940 IREFF pins together without diode like in picture below?
2. Is there any potential issues that can occur while „shorting“ resistors to one of TLC pins to change max current? Goal is to reduce resistance to ground from 4K to 2K, this will change max current from ~10mA to ~20mA.
Current limit will be set only on power on, this design is for a reason...
TLC sets max current according to current flowing from IREF to ground, so I'm assuming my circuit should work, but I need to use 3 times lower resistors than usual due to triple current flow needed for all 3 TLCs, am I rights?
Thanks
