Author Topic: CADDOCK 1776-C48 odd resistor dividor?  (Read 8377 times)
Offline FelicitusTopic starter
« on: February 12, 2014, 10:08:22 pm »
I have watched Dave's Review of the Agilent U1253A OLED Multimeter (EEVblog #56), and I had a look at the resistor divider they used (CADDOCK 1776-C48). When I calculate the division factors, I get a result of like 9.000090001, which sounds rather odd. Can anybody shed some light on what's going on and why Agilent decided not to use the traditional 9M/900K/90K/9K/1K divider?
Offline Rerouter
Re: CADDOCK 1776-C48 odd resistor dividor?
« Reply #1 on: February 13, 2014, 02:00:26 am »
it may be to cancel out the resistance to ground of the adc sample and hold circuit,
Online Jay_Diddy_B
« Reply #2 on: February 13, 2014, 03:09:54 am »
Those resistors values can be used to make divide by 10, 100, 1000 and 10000 with switches to ground:
The conventional divider requires floating switches.
So the Caddock 1776-C48 is probably easier to use in auto-ranging DMMs.
Jay_Diddy_B
Offline ludzinc
    • My Misadventures In Engineering
« Reply #3 on: February 13, 2014, 03:59:06 am »
Hey Felicitus
Thanks for asking this question - I've been also trying a DIY auto-ranging circuit based on the traditional divider tree and also was stumped with the whole 'not blowing up your switch' issue.
Suggestions about using floating FETs are fine, but I couldn't work out how to drive the FET.  This approach is awesome in it's simplicity!
« Reply #4 on: February 13, 2014, 04:02:26 am »
You are my personal hero of the day! Not only have you found the answer, but also answered my other question as well! I just simulated this with a diode clamping circuit, and it works very nicely! Thank you so much, I was banging my head against the wall for like a week or so!
cheers
Feli
Offline capnregex
« Reply #5 on: April 14, 2014, 02:58:42 pm »
I know this thread might be a little old, but now I'm wondering what to use to switch the divider with?
Offline Zero999
  • 0999
« Reply #6 on: April 14, 2014, 10:18:49 pm »
A MOSFET with low leakage current and high enough voltage rating to handle the open circuit voltage, would be ideal.
Offline Rerouter
« Reply #7 on: April 15, 2014, 02:56:18 am »
In this case it only has to withstand the clamping voltage, allowing you to use some extremely low leakage ones,
Offline David Hess
  • DavidH
« Reply #8 on: April 19, 2014, 10:56:48 pm »
So the input resistance varies depending on the range selected?
I thought it was bad enough when multimeters switch to high input resistance on low voltage ranges without notification.  I assume for the intended use this annoying property is irrelevant.
Offline leonerd
« Reply #9 on: July 21, 2017, 11:48:07 am »
I am wondering this too. In fact I started a new thread on the subject; https://www.eevblog.com/forum/projects/analog-switches-for-volt-meter-range-switching/msg1261795/#msg1261795
