Author Topic: Importing a component into MultiSim 13.0  (Read 2264 times)
Offline MCPorcheTopic starter
« on: February 25, 2015, 08:52:02 pm »
I downloaded a project file that someone created with MultiSim 10.0.  The circuit includes an LM317 Adjustable Voltage Regulator.
This component is not included with the library that comes with MultiSim 13.0.  I tried to copy the Spice model data, and create a new component.  However, it doesn't work as it should.  I made a circuit out of the one from the project I downloaded, and with the resistors I used, I get 3.317V.  When I replace it with the component I created, I end up with 11.996V.
Is there some way to take a component from a circuit, and save it into your database?  Or could someone maybe point me in a direction to troubleshoot why the component I created didn't work?
Thanks.
Monte
