Hi everyone,
I'm working on a high voltage differential probe to help troubleshoot the primary of my tesla coil. This is my first PCB design project that requires some serious thought about design and layout to maximize bandwidth, so I'd like some feedback.
I have been using this page as a bit of a guide, but have also simplified it down some to have fewer parts and also worked on the CMRR.
https://www.eevblog.com/forum/projects/oshw-diy-1kv-100mhz-differential-probe-(dilemma-vs-hope)/Requirements:
+-2kV input transient, +-1kv min
flat response out to 20MHz
6-10Meg input impedance
Short summary of design:
I am using a high impedance voltage divider to divide the input signal down to tolerable levels. I can select between 1/1000 and 1/100. The total impedance is around 7Meg. I am aware that this will introduce nyquist noise, but I do not really see any better options. I
This is fed into an instrumentation amplifier. The input buffers are made from jfet op amps (opa659) and the subtracting amplifier is the LM7171.
The output is BNC through coax to my oscilloscope.
The op-amp power supply uses 6.5V switching converters, some filters and then 5V linear regulators to hopefully bring the ripple down around 1mV.
I attached a PDF document with screenshots of the schematic and layout. I would appreciate any feedback on that.
Currently, one of my largest concerns is reflections. I tried to keep trace lengths as short as I could and maintain a continuous ground plane beneath signal traces, but I do not know much about reflections other than sudden changes in impedance can cause them. Is this something I need to worry about? I am specifically concerned about the output of the probe (low impedance diff amp output) to my scope input at 1Meg 20pF.
Thanks in advance for any help!
