Author Topic: Looking for switching regulator with serial control  (Read 657 times)
Offline bill_cTopic starter
« on: January 15, 2020, 04:10:20 am »
My first post here!
I am looking for a switching regulator or controller that I can connect to a micro via SPI or similar to drive a proportional hydraulic valve (36W solenoid).
Regulating current instead of voltage would be better since the coil resistance changes with temperature.
Rated input needs to be above 24V, output needs to be 24V or more and 1.5A or more.
I will be constantly changing the setpoint so faster response and serial coms are better. 8 bit setpoint minimum.
Anyone know of a suitable part?
Or would I be better off using an analog out from the micro to offset the feedback to a standard switching regulator?
I tried PWM with a MOSFET which did function, but it lacks regulation and the 20+ feet of wire would make a fair bit of noise.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Looking for switching regulator with serial control
« Reply #1 on: January 15, 2020, 05:25:26 am »
How about a serial DAC like MCP4921, followed by a power op-amp, or tweaking the feedback pin of a linear or switching regulator?
1.5A may be a bit above the range of most LED/backlight drivers, but that comes to mind as a product line that's tailored around supplying constant current.  Some are continuously dimmable (rather than PWM gated), or you can do the "tease the feedback" trick all the same.
Also consider normal regulators, the ones with current mode operation, and a transconductance error amp, with external compensation.  These, the COMP pin voltage corresponds to output current, so just overdrive that directly.  Mind, there's usually peak detection and slope compensation involved, which mean the setpoint will not correspond to current exactly, and you may want an old fashioned current sense resistor (maybe with a sense amp) and error amp to get an accurate response.
Or you can use a regular regulator in a low-side-sense current feedback configuration, which drops VREF across the sense resistor.  Which sounds annoying, but bear with me.  If VREF is 1.24V say, that's kind of a lot (several watts at 1.5A), but you could use an amplifier to boost the signal, so that only say 124mV is needed (10x amp).  Preferably, you can find a regulator with a lower VREF; 0.8V is pretty common (0.8V * 1.5A = 1.2W).  Not sure if you can find lower.
Seven Transistor Labs, LLC
Offline Giaime
« Reply #2 on: January 15, 2020, 12:55:30 pm »
You might take a look to Ti's TPS92518.
« Reply #3 on: January 16, 2020, 01:30:38 am »
That TPS92518 looks like it just might work, going to give it a try.
