I got this i2s to AES audio converter board and like to use this on my own projects - so I have to identify all parts on it:
Can't get any hint on U2 (the smaller IC 20 pin)
On the left side, this is an WM8805 =>
https://statics.cirrus.com/pubs/proDatasheet/WM8805_v4.5.pdfMiddle top, this is an DS8921M =>
https://www.ti.com/lit/ds/symlink/ds8921.pdfright side, this is an transformer PE-65612NL =>
https://www.mouser.at/datasheet/2/336/-370369.pdfthe unknown part is an P44AD, V244
It seems to be some kind of buffer.
On side pins 1-10:
Pin1 goes to the 2 row pin header and is labeled "OSD_ON"
Vias go to the 4 drill holes left of the chip marked "I2S".
The 4 lines to the 2 row pin header are labeled also with I2S on the bottom side.
pin 10 is ground
pins 11 - 20:
4 lines through melf resistors are I2S lines (output on the P44AD, input on the WM8805)
pin 19 goes to the JMP2 and is connected to ground. JMP3 is open and connects Pin 19 to Pin1 if closed.
pin 20 is VCC 3V3
Maybe someone any hint about this part U2?
