Hi fellow forum members,
I want to build an USB to RS232 converter with variable pinout. It will be part of a "smart" serial terminal server, which can adapt to any pinout and doesn't need any adapters.
To do this, I need a bidirectional level shifter to translate 0/3.3V to +12/-12V, which are needed for RS232.
I can't use a MAX232 with the TX and RX pins connected together (see attachment), because its output doesn't have a high impedance mode, and as a result always forces a state.
I also can't use pullup/pulldown resistors, because the converter has to be able to work with high baud rates and long cables.
A direction signal is available for each pin.
Do you have any idea, how I can solve this problem?
I can't wrap my head around this right now
Thanks for your help,
Moritz
