Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Identifying the motor type in a microscope stage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Identifying the motor type in a microscope stage (Read 75 times)
amaschas
Regular Contributor
Country:
checking for causal domain sheer
on:
Today
at 04:12:38 am »
In the continuing saga of my attempts to get and old 2-axis microscope stage working, I've run into a bit of a roadblock in identifying the type of motor that drives the two axes. I initially assumed it was a 2-phase stepper motor, but I've found some information that indicates it might be a servo motor instead. The motor in question looks like this:
I has 4 leads, a red/black pair and a blue/white pair. The blue/white pair is marked +/-, and the red/white pair is unmarked. There's also a symbol on the top that you can sort of see here:
There's also an encoder mounted on the end that has 4 blue leads:
I've found similar motors being sold:
https://www.capitolareatechnology.com/escap-23hd-motor-11-216e-204-1-leica-pn-302-050087-003.html
https://myvisionsurplus.com/products/escap-motor-gear-23hd11-216e-204-5
And this post which describes it as a servo with an attached encoder, but the motor in this post has 6 pins total, whereas mine has 8 if you include the encoder:
https://rogerparks.com/instructional/escap-16-gear-motor-encoder
In the documentation for the controller for this type of microscope stage, however, the pinout for the motor inputs would seem to indicate that it's a stepper, as the motor pins for the axes are documented in this format on page 7 of the linked PDF:
Motor 1, Phase 1 +
Motor 1, Phase 1 -
Motor 1, Phase 2 +
Motor 1, Phase 2 -
https://www.marzhauser.com/fileadmin/Dateien/Downloadbereich/Steuerungen/TANGO/Treiber_Firmware_und_Dokumentation/TANGO_Desktop_E/TANGO_Desktop_Operating_Manual_EN_130409.pdf
Any help in identifying what kind of motor this is would be appreciated!
Last Edit:
Today
at 04:19:11 am by amaschas
Logged
H.O
Frequent Contributor
Country:
Re: Identifying the motor type in a microscope stage
Reply #1 on:
Today
at 04:47:31 am »
Definitely looks like a PMDC servo motor.
Tachometer on the back (blue wires), motor armature (red wires) and with the encoder mounted on the output shaft.
The ESCAP16 gearmotor with encoder you link to lacks the tachometer, hence 2 wire less.
Last Edit:
Today
at 04:49:54 am by H.O
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
