Problem:
I have a 2" x 2" board with all components on the top side, including a through hole connector with leads soldered from the bottom. Unfortunately that through hole connector is non-optional. The board is mounted on short standoffs so the through hole pins don't touch the heatsink. I need to conduct heat from the bottom of the board to a heatsink so I need a thick thermal pad of some sort. Something in the 4-5mm range is about the spacing.
I was looking at something like this:
https://www.amazon.com/dp/B086VZ9YW3Problems with this:
1) Amazon is not a reliable source
2) I would need to stack two pieces
... Anyone know of a comparable thermal pad type product that
1) Isn't crazy expensive and comes from a reliable source?
2) Ideally already about 4-5mm thick.
3) Comes in a form factor (sheet) that can be die cut.
Notes:
1) Yes I could mill a little pocket in the heatsink where the through hole pins are, but I don't think people would appreciate paying for an extra machining op.
2) Also the connector effectively snaps in, so it's not really possible to just solder it in so the pins don't stick out as much.
3) Something like a thermal epoxy would need to be really thick to not run through/around the board and would make rework impossible, so that sucks.
