Author Topic: Identifying part in handheld transmitter  (Read 1501 times)
Offline pipingmikeTopic starter
« on: August 15, 2023, 03:12:43 pm »
Hello,
I am recycling an old handheld door buzzer in a project of mine and am familiarizing myself with its internals. It is from Linear Corp, model DXT-23, with part number SNT00377. It operates at 315MHz at 3.3 volts from two 2032 batteries. I have come across this RFM module where I cannot find a data sheet for it and websites that appear to be selling it do not have pictures of it to confirm it is the same part I am looking at. I have emailed support of who I think is the manufacturer (https://www.rfmi.co/) is and they do not have the part number in the system. Any help is appreciated  :D .
Bonus: If possible can anyone verify the value of this inductor? I have a rinky dink plastic caliper to measure the length and diameter. It's measurement were:
N: 10
Diameter: 2mm
Wire thickness: <1mm
length: 4.5
using a calculator I got .0072 micro H and noticed standard is .1 uH, if I tweak diameter to 2.4mm I get around that value. Let me know if you think .1uH is a good bet.
Here is Imgur Album with related photos (Board Overview, RFM up close, Inductor up close, board info, rinky dink caliper)
https://imgur.com/a/WYPXCOq
Thank you
Offline floobydust
Re: Identifying part in handheld transmitter
« Reply #1 on: August 15, 2023, 04:41:28 pm »
The TO-39 metal can is a common 315MHz SAW resonator. Nowadays they are smaller SMT and even using a PLL and crystal oscillator with an IC. You can get bushels of 315MHz TX boards on eBay or Aliexpress.
The following users thanked this post: pipingmike
Offline wasedadoc
« Reply #2 on: August 15, 2023, 07:06:30 pm »
Many of those boards are made in 315 and 433 MHz versions. If going that route be sure to select the 315 model.
