Author Topic: Battery powered led project  (Read 2493 times)
Offline vgamesx2Topic starter
« on: May 29, 2017, 01:18:05 am »
I figured I'd share my little led project, the main couple uses I came up with is using it as a slightly better solar garden light or as a light that you can place somewhere that might be a bit of a hassle to hardwire.
Parts list:
TP4056 charging/cell protection - https://www.aliexpress.com/item/1pcs-5V-Micro-USB-1A-18650-Lithium-Battery-Charging-Board-With-Protection-Charger-Module/32477066539.html?spm=2114.13010608.0.0.xYnQmY - $0.31
MT3608 boost converter - https://www.aliexpress.com/item/MT3608-2A-Max-DC-DC-Step-Up-Power-Module-Booster-Power-Module-For-Arduino-3-5V/32717135070.html?spm=2114.13010608.0.0.xYnQmY - $0.44
RF LED controller - https://www.aliexpress.com/item/1set-Mini-Wireless-Single-Color-Remote-Control-Dimmer-DC-12V-11keys-RF-LED-Controller-for-led/32648399134.html?spm=2114.13010608.0.0.xYnQmY - $1.53
6V 0.6W solar panel - https://www.aliexpress.com/item/Portable-Mini-6V-0-6W-S-olar-Panel-Power-Poly-Module-DIY-Small-Cell-Charger-Solar/32738823484.html?spm=2114.13010608.0.0.xYnQmY - $0.84
720mah Lipo - https://www.aliexpress.com/item/3-7V-720mAh-25C-Lipo-Battery-Spare-Part-for-Syma-X5-X5C-H5C-X5SC-X5A-RC/32513708248.html?spm=2114.13010608.0.0.xYnQmY $2
5PCS box - https://www.aliexpress.com/item/5pcs-Waterproof-Plastic-Electric-Project-Junction-Box-55x35x15mm/32697139571.html?spm=2114.13010608.0.0.gPPHRs $1.2 (currently cost more)
10Pairs JST DS connectors - http://www.ebay.com/itm/222438275386?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT - $1.5
LED strip - I already had some but 5M of non-waterproof should cost about $5 and waterproof about $8.
Total cost per light is roughly just $5 each, a bit more if you decide to grab a larger box which can also house the battery inside it and you'll probably want some sort of sealant in order to keep moisture out of these boxes.
« Last Edit: May 29, 2017, 01:21:37 am by vgamesx2 »
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
Re: Battery powered led project
« Reply #1 on: May 29, 2017, 11:30:56 am »
With this solar panel and battery, it will take a few days to charge the battery.. is it acceptable for you?
« Reply #2 on: May 29, 2017, 03:14:58 pm »
Yes, the idea was to only run it when needed, which one of the reasons I added a remote, with those leds it should have a runtime of almost an hour at max brightness and I only planned on using it at maybe half brightness for at most 10 minutes at a time or have fewer leds and instead of it being solar powered putting it say in a hallway and just manually charging it once a week or so.
Offline Audioguru
« Reply #3 on: May 29, 2017, 09:42:53 pm »
Is the cheap Chinese Aliexpress solar panel made with a plastic cover or a glass cover? The plastic covers on my cheap Chinese solar garden lights get sunburned and fail soon. The newer ones have a glass cover and they stay working well for a long time.
The Li-Po battery has a very low price. Is it any good? The batteries that came with my Syma drones are good but cheap "replacement" batteries might be bad.
Online Zero999
  • 0999
« Reply #4 on: May 29, 2017, 10:01:30 pm »
Going by the photograph, the solar cells appear to be potted, which should be very reliable, as long as the resin is UV resistant.
« Reply #5 on: May 30, 2017, 08:13:56 pm »
Hero is correct it's potted in epoxy, the bigger failure point on this cell would probably be if you left the solder joint exposed and it becomes corroded, but you can get similar 1W solar cells for about $1, only reason I went with a 0.6W cell is because I was on a tight $20 budget, with a bunch of other junk in my cart, so I actually needed the extra 15 cents I saved going for a smaller cell in order to cram as many things as possible into my cart.
As for the battery, I haven't really tested yet, I mean since it was only $2 I didn't really care too much, I'll give you an update hopefully in a few hours.
« Last Edit: May 30, 2017, 08:27:18 pm by vgamesx2 »
Offline Audioguru
« Reply #6 on: May 30, 2017, 09:03:40 pm »
Maybe my cheap Chinese solar panels on solar garden lights got destroyed by acid rain, not by sunburn. The ones that I coated on an exterior UV-resistant wood finish last for a long time.
« Reply #7 on: May 30, 2017, 11:33:38 pm »
The results are in, I fully discharged the battery to the point it wouldn't give 100ma at 3v and then charged it up at 300ma and it's actually 650mah not quite the claimed 720mah but I'd say that's still great for $2.
Yeah it's not the most accurate or scientific way of getting the capacity but close enough for me.
