Author Topic: Identify diode part number  (Read 605 times)
Offline JohnnyPTopic starter
    • J&S Electronics
« on: October 06, 2019, 03:53:43 am »
I'm reverse engineering a circuit and need to know what diode they are using.
It's an SMB size.
In the top row it says R 1 7
In the bottom row it says fpA42
« Last Edit: October 06, 2019, 04:45:46 am by JohnnyP »
Thinking is hard work
Offline jhpadjustable
  • Salt 'n' pepper beard
Re: Identify diode part number
« Reply #1 on: October 06, 2019, 05:09:59 am »
If you search "smd marking r17" on the web, you may find an SMD marking code book with the answer. Does a 1N4007 seem about right for the circuit?
https://www.onsemi.com/products/discretes-drivers/diodes-rectifiers/rectifiers/mra4007
"There are more things in heaven and earth, Arduino, than are dreamt of in your philosophy."
    • J&S Electronics
« Reply #2 on: October 06, 2019, 06:25:17 am »
Just looked it up on Mouser.  I think you've got it.
I used 800v S2K/KA from Diodes Inc thinking they would be better.  Now I have to figure out why they didn't work.
    • J&S Electronics
« Reply #3 on: October 06, 2019, 06:30:20 am »
Welp, wasn't the diodes.  I think I know what's going on...
