I am planning to use tactile switch to turn ON & OFF the circuit, can any one of you suggest IC for the same. I am not using any micro-controller in my circuit. I am thinking of using TPS3422 single channel push button controller, but after reading the datasheet, we can see there are two ports RST(invert) and Reset in the TPS3422, so how we can use TPS3422 without controller.
Regards,
Tapas
