Author Topic: Triac Circuit with Voltage Divider.  (Read 2301 times)
Offline BskitterTopic starter
  • Country: cz
« on: November 09, 2017, 06:53:28 pm »
Hello People.
I have a question here, but first a little background story. I have an SMD station that lost its magic smoke a while back. So I made a little project to fix it. I am basically redoing all the electronics inside.
I have basically complete the interface for it (The Temperature display and Pot readings) I am now doing the power control circuit for the Air Pump and Element Control...
So here is the question. On the old circuit there was a Bridge Rectifier on the output of the triac going to the pump. After a lot of searching and asking my Professors at the university I found out that this Rectifier acts as voltage divider for the inductive load.
Below is the schematic.
Now here is the new circuit ill be using to control the Pump.
I am gonna use the Microcontroller to control the speed of the motor.
Now. How do i connect the bridge rectifier to the Optocoupled circuit ?
I am thinking of something like this.
Any suggestions would be appreciated  :-+
Byron
Offline NiHaoMike
    • Facebook Page
Re: Triac Circuit with Voltage Divider.
« Reply #1 on: November 09, 2017, 08:08:51 pm »
The arrangement with the diodes improves control at low levels. It is not needed with a SSR.
http://techno-fandom.org/~hobbit/lighting/dimmer.html
Offline Benta
« Reply #2 on: November 09, 2017, 11:16:07 pm »
As far as I can see, the bridge rectifier in your first schematic doesn't do anything at all. Have you oriented it correctly?
Offline Andy Watson
« Reply #3 on: November 09, 2017, 11:45:41 pm »
It removes a "hysteresis"  effect at low power settings by returning the timing capacitor voltage to zero each new half-cycle. The link that NiHaoMike provided explains the problem.
