I want to test and bin CT's, the input range is 5mA to 10A, and the desired frequency is 40 ~ 100Hz, Basically would be used like this a single turn wire would pass trough the CT under test, and test currents would be generated to measure the Output of CT, so I need to apply an ARB sin wave, this part is easy I can use 16Bit DAC to generate a sin wave with the desired frequency and an amplitude of say 3.3V, Now I should convert this to a constant current, this simple circuit would came to my mind, But I think it would add some DC content to the current, and the output would not be a pure sine wave, so What do you suggest that I would do?
