Author Topic: Power MOSFET switch over heating. Melting solder,  (Read 3228 times)
Offline guscrownTopic starter
« on: October 20, 2012, 05:17:35 am »
Alright, continuing with the debugging of my new board tonight I found another issue worse than the one before: My switching MOSFET is getting so hot that I'm getting molten solder.
I replaced the MOSFET with a short circuit just to see if the components sorounding the MOS were the cause of the problem (mostly a big Inductor I have right next to it) but the copper reaches a temperature of 110F, not enough to melt solder.
This is my schematic:
As you can see, my Vgs is around -11V and I'm running 3A through it using an Electronic Load. Based on the datasheet here: http://www.onsemi.com/pub_link/Collateral/NTD20P06L-D.PDF this thing can do up to 15.5A.
Any ideas of what might be going on?
The only thing I could think of was that the heat on the copper could be increasing Rds(on) but at that particular low current it shouldn't be so serious.
I am using the TO-252-3, DPak (2 Leads + Tab) package.
Offline Rerouter
Re: Power MOSFET switch over heating. Melting solder,
« Reply #1 on: October 20, 2012, 05:25:41 am »
if you dont switch your mosfet very fast you it acts like a big resistor, that 100K is far too weak a pull up, configure a pnp-npn push-pull amplifier on the output of your op amp instead, you really need it moving quickly, to prevent all that heat as it slowly turns off,
« Reply #2 on: October 20, 2012, 06:06:29 am »
I am not switching it. It is being used in steady state.
Offline amyk
« Reply #3 on: October 20, 2012, 06:14:36 am »
Then it's not switched on fully and still acting as a resistor. Measure the voltage drop across it.
Online SeanB
« Reply #4 on: October 20, 2012, 06:19:45 am »
You need to be using a P type mosfet there as a high side switch. You will have a high voltage drop across it in this application, probably 6V or more
