hi all,i was desoldering the main on off switch on my SI4732 based receiver,i was using a hot air station to remove it,problem was it has 2x chip capacitors between the battery main + and ground,they are too small for me to solder back on the board,am i right in thinking its just a bypass cap for the ldo? so say a 330nf should do the trick ?,tia.
