Just seen the cost of those things
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
.Youl cost yourself a fortune using those ,It's power dissipation capability is not that good if you look at thermal details .
Stick to discreet transistors . If you want both source and sink capability then make a discreet mosfet push pull output stage ,study output stage of opamps for an idea.
