Here is possibly a simple idea for No Clean flux.
Most technical papers seem to indicate testing with Glutamine ,Serine, Lysine, Alanine as fluxing agents for No Clean flux types. Since these are Amino acids and are common supplements I thought I could make something quickly.
Glutamine seems to be the most potent in these.
Alas ,I didnt have any glutamine but I did have Lysine .
I did an approximate 5-10 % W/V . Ie 10g in 100ml , in my case 1gm to about 10-15 ml distilled water. Powdered the pills and dissolved them .
I filtered out the undissolved residue .I beleive they are Magnesium Stearate and Calcium Phospates.
Threw the rest of the solution in a dollar store
bonpen-fluxpen clone.
Results are looking good!!
I was able to solder a few sample bits of metal with no issues. This is in addition to copper pcbs/components etc .Aluminum did not work , but that was me shooting for the moon with a 5 dollar soldering iron.
I did an A/B test with some oxidized wire and tests passed. There is definitely some fluxing activity.
It evaporates pretty quickly and does not provide a covering layer (tbh , I didn't need that feature).
Soldering tip gets very clean and stays clean.
As always ,take precautions against chemicals, don't breathe the fumes.Also not sure if this will erode the soldering tip coating faster than rosin ,so another unknown to think about .
HTH someone.
https://patents.google.com/patent/US3675307A/
