Author Topic: Barbed pcb wire crimped end  (Read 2201 times)
Offline CirclotronTopic starter
« on: June 24, 2015, 04:36:21 am »
Hi all. Just looking to find out what these things are called. They go on the end of a wire that is then inserted through a pcb hole and the barb makes sure that the wire is held securely until it is soldered. I want to find out what they are called so I can get some drawings etc as regards what pcb hole size to use with what sized wire and crimp thingy.
Offline German_EE
Re: Barbed pcb wire crimped end
« Reply #1 on: June 24, 2015, 06:14:16 am »
The mechanical termination is called a ferrule but I have never seen lockable devices like this one.
Warren Buffett
Offline apelly
  • Probe
« Reply #3 on: June 24, 2015, 07:30:15 am »
I've often seen them used in PC power supplies, for all of the power leads.
16c each et e14 seems to be taking the piss a bit though.
