Now you've got me thinking...
Which way does Mars' Equator spin?
If the opposite of Earth, does that mean the CPU clocks would have to run at negative frequencies?
We are already running at negative frequencies, because the electron charge was incorrectly polarized a long time ago.
So what we call "Positive" is actually Negative.
Similarly what we call "Negative" is actually Positive.
Hence the negative frequencies.
This is why, despite massive increases in performance frequency, approximately doubling every two years (Moore's law), we actually see e.g. Windows10, with a 4 GHz 8 core processor, actually run a bit slower, than an ancient 4.77 MHz single core cpu (8088), running Dos and the same, simple application (e.g. a text editor).
tl;dr
So on Mars a Windows10 machine would actually run, about a million times faster, compared to Earth.
Anyone who does not believe me, will have to fly/travel over to Mars and perform experiments to disprove me, otherwise I am
RIGHT, since I said it first**.
**There
CAN'T be anything wrong with that argument, because a number of other internet forum posters (around the internet), use it.
