Author Topic: Remove 14 pin header from step file  (Read 271 times)
Offline JesterTopic starter
« on: September 03, 2024, 11:04:55 am »
I have a step file for a 240x320 ILI9341 style display. As provided it has a 14 pin header that I need to remove from the step file.
If someone here can do this, it would be much appreciated.
« Last Edit: September 03, 2024, 11:12:07 am by Jester »
Offline robson2017
Re: Remove 14 pin header from step file
« Reply #1 on: September 03, 2024, 11:31:52 am »
Hello,
I don't know if that's what you meant?
R.
The following users thanked this post: Jester
« Reply #2 on: September 03, 2024, 12:39:17 pm »
Hello,
R.
That is perfect!
Very much appreciated!
Out of curiosity, what program did you use to delete the header?
Have a great day.
Offline robson2017
« Reply #3 on: September 03, 2024, 02:32:05 pm »
I used Autodesk Inventor because that's what I have, but it could also be Solidworks, etc.
Have a nice day.
Offline BennoG
« Reply #4 on: September 03, 2024, 06:02:22 pm »
solid edge is free for home users.
It si from siemens.
Benno
Offline Doctorandus_P
« Reply #5 on: September 03, 2024, 06:19:04 pm »
I did the same in FreeCAD. Just a simple:
1. Extract the zip to step.
2. Open in FreeCAD.
3. Delete the connectors (there are three of them, each with just some pins for some reason).
4. Export.
5. Zip up again and post.
Creating the screenshot and typing this post is more work then the actual deletion of the header.
A possible thing left, is that it has the LCD, which has a red PCB on itself, and there is another green PCB with nearly the same size. I just left both of them in the file.
2360137-0
I've been using FreeCAD for quite some years now. It's growing slowly in capability and user friendlyness, but it still has some way to go before a V1.0 release. And of course, together with it's Open Source nature, there is no way any company can ever hold my data hostage to extort (more) money or force me into the mist (cloud) with perpetual monthly subscription fees.
