Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
PWM Fan Controller - how to get a stable frequency?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: PWM Fan Controller - how to get a stable frequency? (Read 1928 times)
Didix
Regular Contributor
Country:
on:
May 01, 2015, 05:49:32 am »
Intel's specification for 4-Wire Pulse Width Modulation (PWM) Controlled Fans asks for a 25kHz modulation:
http://www.formfactors.org/developer/specs/4_Wire_PWM_Spec.pdf
Nidec proposes a NE555 based circuit:
http://www.nidec.net/apps.htm
This circuit works for my fan - so far that's fine.
However, the frequency strongly changes when changing the duty cycle (10kHz .. 20kHz).
How could I do better to get a much more stable frequency when changing the duty cycle (by using a NE555)?
-Didix
Logged
Fluke 76 | UT61E | UT139C | UT70A | UT50E | UT132A | UT33C | UT203 | UTG9002C
void_error
Frequent Contributor
Country:
I can transistor...
Re: PWM Fan Controller - how to get a stable frequency?
Reply #1 on:
May 01, 2015, 06:09:02 am »
Move the 1k resistor from the output to the wiper of the 100k pot, that way any load at the 555's output won't affect the frequency that much. In other words, short the 1k resistor and put one 1k resistor between the 100k pot wiper and the TRIG-THRES node.
Logged
Trust me, I'm NOT an engineer.
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Reply #2 on:
May 01, 2015, 06:28:23 am »
The inverter in the fan motor won't mind a big swing in PWM frequency. In fact, after the input level converter, it most likely either goes into a low pass filter or a gated counter, with maybe a few Hz of control bandwidth.
Logged
Didix
Regular Contributor
Country:
Reply #3 on:
May 01, 2015, 01:39:41 pm »
Meanwhile I have replaced the capacitance to 300pF.
To neglect the influence of the load I have removed it.
This does not heavily change the fact, that the frequency covers that wide range (21..38kHz).
I have also moved the 1k resistor as proposed to the wiper.
This changes the effect when having the load connected a little (24..36).
However, when the load ist unconnected I still see the same wide range (21..38).
-Didix
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
