I don't understand. What you're describing sounds to me as if the NTC is limiting the current draw. Isn't that what it is supposed to do?
Yes, the NTC is behaving as designed. I am saying it doesn't achieve what I want.
With the NTC I most recently tried, I measure a resistance of ~6-6.5 ohm when it's cold.
The station draws very roughly 200mA at idle. If I connect the NTC across the output of my bench power supply and set it to 200 mA, after a few moments the voltage drop is 0.74V, so it has dropped to 3.7 ohms. It took about 30 seconds to reach that resistance.
If I then suddenly increase the supply current to 2.2A, the voltage drop across the NTC spikes to >3V, drops to 1V within 1 second, and after a few seconds it reaches 0.74V and seems mostly settled there, about 330 mohm.
What I'm demonstrating here is that the NTC is not an instantaneous current limiter--its resistance reacts very slowly to the current averaged over a fairly long period of time (seconds). When you pick the iron up out of the stand and the system's draw jumps from 200mA to 2.0A, the input voltage presented to all of the regulators on the board will drop suddenly by ~6-7V. The regulators then have to draw *even more* current to drive the same output power, and there will be some momentary instability over the fairly long timescale while the NTC warms up and its resistance decreases.
I think NTCs are just ill-suited for what I'm trying.
If the problem is a glitchy display, could it be that the metal bezel of the LCD is grounded to the case?
I was seeing display freezes and blanks very frequently until I bypassed the NTC. Now I am only seeing uC resets much less frequently, so I think I removed at least one component of the problem.
Another possible issue is that the cheap DC-DC converter module might just not have enough input capacitance. I wonder if placing the NTC only in series with the RF supply and connecting the 10V converter's main input directly to power might help? Again though, not a big deal as the inrush limiting seems largely unnecessary.
Interesting. I would have thought that a bigger problem was that the NTC stayed hot during momentary power glitches and failed to limit the subsequent rush of current as the cap recharged.
This isn't actually the goal of the inrush limiting. I only want to limit the initial large current spike when the cap charges up from zero. The current waveform after that should be much smoother due to the capacitor. If the supply voltage suddenly jumps that's a problem with the power supply and I don't intend to protect it from itself.
