I am using LM393 op-amp as zero crossing detection.
circuit uses dual supply with positive and negative supply of 5V as I have differential signals.
When I connect signal it creates square wave according to input, but due to inherent noise in input comparator output is also noisy near transition.
Is there any way I can remove or reduce input noise when no signal is connected to opamp(i.e. inherent noise of input) So I can get clear output. I am using both the op-amps of dual op-amp IC LM393 as I have two different signals.
