Author Topic: Transistor question  (Read 1783 times)
Gazucha
  • Guest
Transistor question
« on: October 04, 2013, 01:32:18 pm »
 Hola,
  I have a project which has two 450V 10A NPN transistors in the circuit and I haven't found a suitable data-sheet.
 One is stuffed. Which is being changed.
 On a diode test, the other reads 0.385 and 0.502 when measured, which seems to me to be a large difference.
 So, the question is,
  is the transistor still within functionable parameters with those readings, or could it possibly fail alongside a new partner?
 Cheers.
Offline Alana
Re: Transistor question
« Reply #1 on: October 04, 2013, 01:38:33 pm »
First - do you mesure it desoldered completely?
Gazucha
  • Guest
« Reply #2 on: October 04, 2013, 01:45:21 pm »
 Yeah, desoldered completely. On the bench.
Gazucha
  • Guest
« Reply #3 on: October 04, 2013, 02:07:15 pm »
 The reason I ask is that if those readings were on, say a BC547, then I would consider it failing...
  and the high voltage, high amperage, transistor field is not my comfort zone.
 I would imagine it would work, but unless someone knows different, then I'm not mad on having such an imbalance in the transistors, as I am fairly sure that the new transistor (C4237) will read 0.600+ on from B to both C & E pins.
Offline Alana
« Reply #4 on: October 04, 2013, 02:17:58 pm »
I'd do the very same thing - if BE and BC are so different its usually faulty. To be sure try to turn a light blub with that transistor - if it works it may be ok but i doubt that.
Gazucha
  • Guest
« Reply #5 on: October 04, 2013, 07:59:34 pm »
Update...
 When tested in the shop, one new 2S C4237 tested 0.548 & 0.445 and another 0.502 & 0.435, so I decided to take a chance and only buy one, the one which tested closest to the existing transistor (which is actually testing 0.514 & 0.397).
 When I saw that the brand new ones also have a large difference in measurement, I realised that perhaps the original transistor is not as bad as imagined?
 That coupled with the fact that to install the 2SC4237 entails drilling and a bit of open-heart surgery,  :scared: it seemed prudent to start with the one that is 100% failed.
« Last Edit: October 04, 2013, 08:05:25 pm by Gazucha »
Offline Paul Price
« Reply #6 on: October 04, 2013, 09:17:03 pm »
With the majority of bjt's there is most common a difference between c-e and b-e readings, and this reading varies with the make and model of meter making this measurement.
