If your need is for an industrial application you need to talk to a mechanical engineer. The electronic (actuator signal) side of valves is somewhat standardized in terms of signal levels, but the mechanical side has various considerations including material of construction, fluid handled, required flow rate, isolation pressure, leak tolerance, speed of operation, fail safe behavior, etc.
In a homebrew situation where you are throwing something together as a hobby you can easily wing it and just choose something suitable from a parts catalog, but more care is required in a commercial setting.
