as I read the kit schematic, it seems to me that it is written 1/2 1458 beside the two aop ?so it should be a LM1458, obsolete, or its actual equivalent MC1458 ?and the LM336 is a voltage reference, not an AOP !even the LM356 is a single AOP ...
In your schematic, I see D4 backwards. Otherwise the circuit remake looks reasonable to me, assuming you are using 1458.
Quote from: kripton2035 on August 19, 2021, 08:08:04 pmas I read the kit schematic, it seems to me that it is written 1/2 1458 beside the two aop ?so it should be a LM1458, obsolete, or its actual equivalent MC1458 ?and the LM336 is a voltage reference, not an AOP !even the LM356 is a single AOP ...I have many LM1458's in stock and the Lm336 are for IC1 and Ic2
