Try kovar or Alloy 52 header seals from HCC Industries, Fusite, MPFPI, Vactron, etc..
You probably could request a sample or two of a stock product from one of these companies.
In my application, I furnace brazed a flanged, octal header "hermetic seal" into a recess milled in a CF flange... To save on buying feedthroughs .. which are all over Ebay if you look... I just searched, and there are a few "hermetic seals" on the bay now, after you dig thru two pages of "occult medallions"(Lord Have Mercy!
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
) Including a 125 Pin one, although it has an O-ring..
I've found 306 SS CF flanges easy to braze with cadmium/silver solders, and then just pump the daylights out of the chamber. If you design it right, the exposed surface area of the braze is minimal.. I know, not optimal to use a hard solder or braze in UHV, but for my app it worked.. If I ever did it again I'd use Indium Corp's Nanobond component bonding instead of a braze.
Steve
