Author Topic: The best home automation systems  (Read 3485 times)
Offline Doctorandus_P
Re: The best home automation systems
« Reply #25 on: August 17, 2024, 08:53:41 am »
The latest innovation is to use a laser pointer to shine at a light switch and a cat.
Offline soldar
« Reply #26 on: August 17, 2024, 09:10:02 pm »
The problem is when the cat doesn't work and you try opening it up to see what might be wrong inside it.
