Author Topic: HP-41800A clone ideas?  (Read 707 times)
Offline WB8PFZTopic starter
« on: March 15, 2020, 02:49:36 pm »
My HP spectrum analyzer needs an active probe similar to the HP41800. Lots of money for something not used very often. Does any one have any ideas to a comparable circuit. I am not doing lab stuff just probing around radio circuits. I was thinking a few MMICs. Thanks Mike
Offline SuzyC
Re: HP-41800A clone ideas?
« Reply #1 on: March 16, 2020, 05:53:44 pm »
Just use a n-chan enhancement mode JFET common-drain follower to make a very high impedance low cap(<5pf) active probe tip that you can make using a tiny piece of PCB copper laminate to attach to the end of a scope probe.  Only limit:  low-voltage circuits, otherwise a coupling capacitor(5pf)/22-meg input resistor G-S would be needed.
You can supply +12 V to the JFET source and set the JFET drain resistor to 50 to 500 ohms to -12V,  maybe OC or  22-Meg gate to source pull-down. The gate to source resistor is not needed once the gate is connected to the circuit point of interest.
« Last Edit: March 16, 2020, 06:18:56 pm by SuzyC »
