Author Topic: Using battery to power logic circuits, feasiblity and pitfalls?  (Read 305 times)
Offline MuriTheMythTopic starter
Hi folks,
I've been working on my project that involves a 100V 20A high-power part, which were driven by +5V logic circuits (plus a -5V rail for op-amp).
Initially I was planning to draw power from the 100V rail and pass through a buck converter followed by LDO to power the logic devices. The -5V is generated by a charge pump followed by LDO.
Though, as a initial prototype, I felt like the converter part is too complex. I'm wondering if it's possible to power the logic rails with lithium batteries. I will need 500mA for the positive rail because gate driver draws, so AA batteries may not work well.
I proposed a topology in the attachment. Please let me know your thoughts on it. Also I would appreciate any possible pitfall you noticed.
Thank you very much for your time!
Regards,
Anyu
Offline ledtester
Re: Using battery to power logic circuits, feasiblity and pitfalls?
« Reply #1 on: July 28, 2024, 04:28:01 pm »
It sounds like the cells powering the positive rail will get depleted faster than those powering the negative rail.
How much current do you need for the -5V rail? If it's not too much perhaps you can generate the negative -5V using a charge pump or a small DC/DC regulator. Then you would only have one battery pack with only one charging/protection circuit.
« Reply #2 on: July 28, 2024, 05:23:30 pm »
That could be done! Thank you for the advice!
Online pcprogrammer
« Reply #3 on: July 28, 2024, 07:21:46 pm »
Why not use a switch mode power supply fed from the 100V rail. Most of these work from 80V to 260V AC, but can also be fed with DC. A simple USB phone charger could be used for this. The negative 5V can be generated with an additional DC-DC converter.
Or search for a SMPS that has both +5V and -5V as an output.
Will be more reliable than using batteries, which need to be charged once in a while, and with 500mA current drawn this might be rather often.
