Use a standard panel mount connector of your choice, terminated in wires. Have a socket on your PCB with a wire-to-board connector. Simple, adaptable, robust, and easy to maintain.
Don't you think that plugging/unplugging could be problematic when you cannot hold a connector top all the way down to the connector on board?
