I got an externder card from an Ebay seller in Korea, around $60, from memory, after searching for ages for the Fluke accessory. Looks larger than the Fluke version, but if I were trying to build one, would probably have one small card with connector at each end, then use ribbon cable to join the two. Would provide more flexibility in terms of card orientation. The power supply is definately fragile and runs quite hot in normal operation, discolouring the boards over time. Probably exacerbated by uk line voltage, often nearly 250 volts. Low value resistors used as fuses, if any problems arise on the power amp, which must have been pushing the state of the art at the time. Got over the heat problem by fitting a small fan in the psu compartment, which now runs much cooler. Well worth the mod.
