Author Topic: World’s sexiest Tesla Coil (Vertical).  (Read 4582 times)
Offline @rtTopic starter
« on: May 31, 2016, 01:20:32 pm »
Any sexier (Vertical) Tesla coil out there pls let me know :D
Bearing in mind it’s an SLA powered baby!! :D
« Last Edit: May 31, 2016, 01:28:00 pm by @rt »
Offline DutchGert
Re: World’s sexiest Tesla Coil (Vertical).
« Reply #1 on: May 31, 2016, 02:28:32 pm »
I want!
Offline nanofrog
« Reply #2 on: May 31, 2016, 03:29:26 pm »
Offline Arjan Emm
« Reply #3 on: May 31, 2016, 03:42:56 pm »
I think mine is sexier  :P
Nicely made though!
Wooden black base like yours and alot of acrylic like yours, including the secundairy.
Shame it needed a recoil after this run.
« Last Edit: May 31, 2016, 03:45:46 pm by Arjan Emm »
« Reply #4 on: May 31, 2016, 05:12:32 pm »
Well it clearly wins  in performance! :D
For mine the secondary coil wire part is about 35cm, but this assembly ends up closer to 60cm.
With regard to aesthetics, those new tube torus shapes have something going for them visually.
However, yours will remain the same, while mine will become many times more sexy  :-DD
Offline tantulatum
« Reply #5 on: June 02, 2016, 02:56:50 am »
I've always like this one.  Fiber optic LCD remote control.
« Reply #6 on: June 02, 2016, 06:55:58 am »
For the World’s sexiest vertical Tesla coil, that could just be assumed haha : :-DD
The nicer keypad from RS is in the cardboard box at the back.
Offline Psi
« Reply #7 on: June 02, 2016, 07:33:06 am »
Fiber optic SS Tesla coil control is very common.
It's not a good idea to have a conductive piece of wire between you and the coil electronics :D
« Reply #8 on: June 16, 2016, 02:20:42 pm »
Ok, One more part to go for this assembly. I have it, but not fitted yet.
It’s a matching acrylic base shape that goes under the ground plane,
so that it looks like a silver band around the perimeter of the base.
For the top disc, it’s kind of a shame it covers the more detailed clear stuff, but it should still be there.
Laser cutting is getting expensive!! :O
Offline alsetalokin4017
« Reply #9 on: June 16, 2016, 03:29:04 pm »
Can I play too?
(Powered by 2 x 12v SLA batteries)
Online Gyro
« Reply #10 on: June 16, 2016, 04:15:53 pm »
Nicely made though!
That soundtrack was worthy of 'Forbidden Planet', particularly the way as the pitch increased.  8)
Best Regards, Chris
