I'm opening a new topic with a question started
here and apologize if such duplication makes any trouble to anyone (and hope that Kleinstein, Strada916, Kean and others will follows up
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
). Just in short: I'd like to introduce multiple ranges (two for the beginning will be just fine: 0-500 mA and 0-5 A) for current monitoring that can be used in power supply for control loop and measurement.
It started with an idea that each shunt has it's own low Rds(on) mosfet in a series as to switch from one range to another in a "make-before-break" fashion. Mosfets will be highly saturated to provide the lowest specified Rds(on) and yes, that mean that Rds(on) has to be added into account for measurement. That should be a problem if calibration is accomplished and that Rds(on) doesn't vary a lot with current and temperature. I don't talk here about "reference instrument" that has to be very accurate, but rather something that can be used in DIYers/hobbyist bench top.
Many thanks in advance for your timely response.
