We do have FP but we don’t do powered testing. We only do parametric measurements, resistors, caps, diodes, shorts. There are options for power supplies though and they can do limited functional testing such as amplifiers gain, comparators, gates, transistors. You clip the power supply before beginning the test, and the program turns it on. However, I understand this is very uncommon.
