Hello.
I need to get 20mA DC at 260 V from 12-16V input, and fit it into a small box.
Question is, what is the best/most compact way of doing it, without exotic ICs or overly-complex inductors?
I have successfully gotten the voltage and power using a push-pull converter with a transformer, driven by a TL494.
Somewhat like this:
http://orbides.1gb.ru/img/inv-sch-hv3.pngHowever, it does not fit the "small box" requirement, and i can't quite see scaling it down too much without making the transformer unwindably small.
Even the smallest i can make is good for 100W, so way overkill as well.
On the other side, there is a boost converter.
I tried one with MAX1771 ( i.e.
http://orbides.1gb.ru/img/max_1771_boost.png ), and it easily fits the size requirements, but it just can't deliver the power needed, dropping out at 2-3W.
So, how can it be done?
Is there a way to make a more powerful boost converter?
Is there some other topology with in-between power level?
