with reference to the attached schematic, would you recommend a slow blow or fast blow?
I was thinking that when initially the circuit receives power C14 and C15 are discharged and there might be a (relatively) large current surge. So a slow blow fuse might be better?
But then again the current surge might be too short to need a slow blow?
Or maybe I should think in a different way when coming to choose the type?
Thank you
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
