Author Topic: how to determine maximum Vref frequency for DACs? (multiplying dac)  (Read 1406 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
So I want to use a DAC as a Multiplying DAC.
Essentially I want to figure out what is the maximum frequency the Vref can be before the DAC output becomes distorted (using it as a multiplier or attenuator).
I understand that MDACs are designed for this, but is there a trick to finding out what the maximum frequency is for any dac so that you are not confined to what is advertized as a MDAC? (multiplying DAC).
Offline T3sl4co1l
    • Seven Transistor Labs
Re: how to determine maximum Vref frequency for DACs? (multiplying dac)
« Reply #1 on: March 08, 2014, 11:02:46 am »
Should be specified in the datasheet.
Usually, they drop off around 200kHz, but beware the error and the cutoff frequency usually vary with code...
Seven Transistor Labs, LLC
