I didn't really make much progress, but I wanted to share some thoughts on power supplies.
I wanted to solder something over the weekend, so I chose that national's lab supply (
https://www.ti.com/lit/an/snoa692/snoa692.pdf). But I think I'll solder something else, here's why.
1. The output is made of 10xLM395, they have 2mA+ quiscent current. All this goes through the shunt. Perhaps, it's not a problem for a 10A power supply, but I wanted some precision.
2.
lm101a is hard to get. I wonder if I could replace it with lm308 . Nevermind, I think I forgot to look for lm301a.
3. lm395 are sorta expensive (~3.5euro). Probably could be replaced with a low-power darlington (mpsa14) driving a beefy bjt. This way base current could be down to microamps, similar to what lm395 offer. Not sure about performance of the replacement.
Overall, I feel like it's hard to beat Harrisson topology. I was hoping to find an opamp or something with clipping. And, believe or not, I found one, which is lt6372. Unfortunately, it's not an opamp, it's an instrumentation amplifier. But might be handy one day
. Loosy specs on clipping voltage
One interesting circuit I found in this post:
https://www.eevblog.com/forum/projects/is-550uf-too-big-for-a-power-supply-that-has-cc-limit/msg2161846/#msg2161846 . I mean the one with lt1010. I like that current-limit amplifier controls the voltage-set amplifier. This way only one opamp needs to be clipped. I can't prove yet, but it feels like it's much easier to make stable crossover betwen CC and CV modes when only one opamp goes into saturation. The circuit still suffers from typical problems, such as CC-opamp steals (or injects) some output current, and it's also high-side current sensing. I played in ltspice with the circuit, switch to CC mode within one or two microseconds look impressive, as well it is stable without output capacitor (or requires very little). I want to build one. Probably, I'll replace lt1010 with cheaper and beefier buf634a (
https://www.ti.com/lit/ds/symlink/buf634a.pdf).
Any thoughts and/or opinions?
