Author Topic: RFID Reader for wide range distance  (Read 660 times)
Offline DIYGUY ChrisTopic starter
« on: April 28, 2021, 10:42:19 pm »
Hello all
I've been playing for while with the mifare 13.56 Mhz RFID Crad reader (like many electronics hobbyists) since the reader distance is limited to 30mm I can't achieve some requirements in one of my current projects so I came here to ask for any recommendation of some UHF readers that I can use to read tags at a distance of 1.5 meters.
I'm using AVRs to interface the mifare through SPI so anything with similar protocol will be highly appreciated  ::)
Offline LakshmiN
  • Country: in
Re: RFID Reader for wide range distance
« Reply #1 on: April 29, 2021, 10:36:28 am »
STMicro- ST25RU3992
Else look for Impinj based modules
https://rainrfid.org/rain-tag-ic-and-reader-resource/
