Author Topic: How to connect a piezo speaker to a microcontroller?  (Read 10737 times)
Offline zaptaTopic starter
« on: January 17, 2014, 06:41:01 am »
I have an AVR atmega328P MCU that generates 5V square wave 2-4Khz and I would like to connect to it a no name 10mm piezoelectric passive sounder I picked at a local surplus store. It measures as 10nF but don't know its inductance.  I read somewhere that the MCU needs protection because mechanical impacts on the piezo, will send high voltage back to the MCU and damage it.
I am looking for a simple way to safely connect the piezo the MCU. Any suggestion how to do it? For example is this a safe and reasonable way?  Should I add a serial resistor between the diodes and the piezo to limit the current due to the piezo's capacitance?
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
Re: How to connect a piezo speaker to a microcontroller?
« Reply #1 on: January 17, 2014, 07:54:35 am »
Piezo element is capacitive, so you want to drive it via a transistor as it takes relatively big gulps of current on every on and off.  That and possible high voltage spikes as you've mentioned
« Reply #2 on: January 17, 2014, 04:51:45 pm »
Thanks miceuz, that's simple enough. I will give it a try.
I saw also similar circuits but with a additional diode in parallel to the resistor.
Offline nctnico
« Reply #3 on: January 17, 2014, 06:36:24 pm »
If you replace the R* with an inductor then you double the swing.
« Reply #4 on: January 17, 2014, 10:01:58 pm »
How do I choose the inductance?  (assuming frequency and piezo's datasheet are given).
Offline nctnico
« Reply #5 on: January 17, 2014, 10:18:36 pm »
Somewhere around 5mH to 10mH should do. You should do the math to determine how long you can turn the transistor on without saturating the inductor. The duty cycle should also be less then 50%.
Offline Zero999
  • 0999
« Reply #6 on: January 17, 2014, 11:20:40 pm »
You should be able to drive a piezo directly from an MCU output and don't worry about the diodes, the MCU has them built in. Just connect the piezo directly to the MCU IO pin.
Offline Baliszoft
  • Country: hu
« Reply #7 on: January 17, 2014, 11:23:28 pm »
I am also driving the piezo directly from the mcu pin thru a 100n cap without any problems.
Offline Zero999
  • 0999
« Reply #8 on: January 18, 2014, 01:55:16 pm »
A series capacitor is not a bad idea is it blocks DC which can be bad for piezos.
For more volume, connect the piezo between two I/O pins and drive them out of phase with one another.
